manlymanagement's avatar
Feb 03, 2017
Prosafe Plus GS116Ev2 VLAN trunking
Hi, I would really appreciate help finding the name for the feature and where I can read regarding configuration.   I require to set up VLAN trunking, forwarding the tag from source to destination ...
  • XavierLL's avatar
    XavierLL
    Jun 21, 2017
    Hi Kc1
    You have to first configure the Switch to use 802.1Q Advanced VLAN, once you do this you should be able to see the Untag and Tag
    Regards
ProSupport for Business
