neverbesuccessf's avatar
Jan 13, 2018
Questions concerning VLAN on GS108Ev3
Hi there
I'm building a network right now and I'm configuring my switch on which leads to the router and then into the network.
Short questions about the VLAN:
A) Have I configured the VLANs correctly? (see pictures)
I want exactly one VLAN per port
B) How do I make sure that the different networks can only access the corresponding VLAN?
e. g. VLAN 4 = printer
Printers should then be connected directly to VLAN 4 on the switch.
Does it have to be done on the router?
Best regards
neverbesuccessfull
  • Ref. the VMs ... it depends on how the interfaces are configured - on the virtualisation host as well as on the VM itself. A system can handle just an untagged network, or multiple services which can talk or offer services to multiple VLANs can be configured for tagging (multiple virtual interfaces), so the port can be either dedicated to one VLAN (untagged), or as a VLAN trunk handling access to multiple VLANs.
ProSupport for Business
