Dai_X
May 10, 2021Follower
RADIUS attribute [Service-Type] empty when using 802.1X on LAN with GS724Tv4 and GC752XP switch
Hello, I've searched on the forum, but I couldn't find anything on this.
We are using our own RADIUS server for 802.1X on LAN with the GS724Tv4 and GC752XP switches. We have enabled 802.1X and MAB (Mac Authentication Bypass) on these switches (using SNMP).
On both switches we see that RADIUS authentication requests are sent to our RADIUS server, MAB is also working. However, we see that the switch does not send the RADIUS attribute [Service-Type]. We are using this RADIUS attribute to determine what kind of RADIUS authentication it is.
See also:
So when it's an 802.1X authentication we would expect the value of this attribute to be "Framed". When it's a RADIUS-MAC authentication (MAB), we would expect the value to be "Call-Check".
We are using the latest software versions on both switches. Are we missing a configuration or switch setting so the RADIUS attribute [Service-Type] will be used by the switch?
Thanks for any help in this.
No RepliesBe the first to reply
