Eelke83
May 07, 2018Aspirant
random port blocks
I have a GS724 switch (fw# 6.3.1.19)
At random ports get disabled. (computers/ printers) (Port config - Admin mode)
after turning the port back on, it falls back to disabled within 30 seconds
W...
- May 10, 2018
Hi Eelke83,
We have two behavior of DoS function.
1. Auto-DoS = Enable, Denial of Service list = Enable
Switch will disable port automatically when specific packets received and also match in Denial of Service list.
2. Auto-DoS = Disable, Denial of Service list = Enable
Switch will drop the packets when specific packets received and also match in Denial of Service list.So i have some suggestion that may help you figure out the root cause.
If you want to keep port status linkup not disable.
Please change Auto-DoS configuration = Disable.
Then manual selected the rule you want in Denial of Service list.(except DoS TCP port + DoS UDP Port)
If you want to disable port when DoS condition work.
Please find following step:
1. Disable one rule of Denial of Service.
2. Monitor every port status that will be disabled or not.
3. Disable another rule of Denial of Service.
4. Monitor every port status that will be disabled or not.
5. Repeat above step to check which rule work in Denial of Service list.
6. Check network environment to clean the harmful device.May the solution help you:smileyhappy:
DanielZhang
May 07, 2018NETGEAR Expert
Hi Eelke83,
Welcome to NETGEAR community!:smileyhappy:
As we know,
NETGEAR smart switches have some automatic disable function when ports meet the conditions.
So could you please check following feature enabled on your Switch?
1. Denial of Service
Auto-DoS Configuration
2. DHCP Snooping
3. Storm Control
4. Port Security
5. Any loop in your network?
Thanks,
Daniel.
Eelke83
May 10, 2018Aspirant
Hi Daniel,
Thank you for your response.
1. Denial of Service = DoS TCP header = 20 / DoS ICMPv4 enabled / max ICMPv4 512 / DoS ICMPv6 enabled / max ICMPv6 512 / all options enabled except DoS TCP port + DoS UDP Port
Auto-DoS Configuration = Enabled
2. DHCP Snooping = disabled
3. Storm Control = Ingress control = disabled
4. Port Security = disabled
5. Any loop in your network? = No, have repatched whole switch to be sure.
- DanielZhangMay 10, 2018NETGEAR Expert
Hi Eelke83,
