Ercivan
Jan 18, 2021Aspirant
Random Port Down -Up
Hello ; There are 24 smart netgear switches in my infrastructure. All switches have the same problem. The port goes up and out. We use Cat 7 SFTP cable. Normally, when it is disconnected with 1 ...
schumaku
Jan 19, 2021Guru - Experienced User
A little more information than "All switches have the same problem. The port goes up and out." would help...
All ports on all switches? Client computer facing port? Uplink port? How are the switches connected?
Any DoS config in place?
How comes a network at this scale does not have any STP or better at least RSTP enabled?
- ErcivanJan 19, 2021Aspirant
1. Example: When a computer is operating normally, the network connection drops after a while. It comes back 5 seconds later. Sometimes it connects as 100 mb when there is 1 gb connection. When you unplug the cable and plug it in, it gets better. The same problem persists when I run it locally with the switch.
2.Backbone: M5300-28GF3
All other switches are connected by fiber cable.
Backbone> FiberCable <Sub Switch <Cat7SFTP <Computer or Ap3. No
4. This problem has existed for a long time. We talked to Netgear via mail. I've been told to turn off stp on all switches.
- schumakuJan 19, 2021Guru - Experienced User
Are these 24 units all GS110TP switches?
What model is shown on the label GS110TPv1 (-100xxx), GS110TPv2 (-200xxx), GS110TPv3 (-300xxx)?
Current firmware version?
Hard to imagine there is an impact on the link or link bouncing - please provide as much information possible on the network config (VLANs, connected computer/access points).
1. These are all my devices. M5300-28GF3,GS752TP V2 , GS724TP V2 ,M4100 ,GS310TP , GS110TP
2. GS110TP V1 , V:5.4.2.33
3. There are 3 vlan.
2. local network for 1st voice 3. telephone network 4. guest networkAP: Unifi
