Ercivan
Jan 18, 2021Aspirant
Random Port Down -Up
Hello ; There are 24 smart netgear switches in my infrastructure. All switches have the same problem. The port goes up and out. We use Cat 7 SFTP cable. Normally, when it is disconnected with 1 ...
Ercivan
Jan 19, 2021Aspirant
1. Example: When a computer is operating normally, the network connection drops after a while. It comes back 5 seconds later. Sometimes it connects as 100 mb when there is 1 gb connection. When you unplug the cable and plug it in, it gets better. The same problem persists when I run it locally with the switch.
2.Backbone: M5300-28GF3
All other switches are connected by fiber cable.
Backbone> FiberCable <Sub Switch <Cat7SFTP <Computer or Ap
3. No
4. This problem has existed for a long time. We talked to Netgear via mail. I've been told to turn off stp on all switches.
schumaku
Jan 19, 2021Guru - Experienced User
Are these 24 units all GS110TP switches?
What model is shown on the label GS110TPv1 (-100xxx), GS110TPv2 (-200xxx), GS110TPv3 (-300xxx)?
Current firmware version?
Hard to imagine there is an impact on the link or link bouncing - please provide as much information possible on the network config (VLANs, connected computer/access points).
- ErcivanJan 19, 2021Aspirant
1. These are all my devices. M5300-28GF3,GS752TP V2 , GS724TP V2 ,M4100 ,GS310TP , GS110TP
2. GS110TP V1 , V:5.4.2.33
3. There are 3 vlan.
2. local network for 1st voice 3. telephone network 4. guest networkAP: Unifi
