NobleSpartan117's avatar
Oct 14, 2018
Cable Modem, Switch, and Wireless Router
I'm trying to figure out how to setup my network.  I have the following equipment: -Arris SB8200 cable modem with 1GB internet -Asus AC-5300 wireless router -Netgear GS752TPP   I'm wonderin...
  • Nodism1125's avatar
    Nodism1125
    Oct 16, 2018
    Link aggregation between router and switch allows your devices to treat multiple Ethernet links as if they were a single link to increase bandwidth or provide fault tolerance. To set up link aggregation, you must create a link aggregation group (LAG) on both devices. Link aggregation between your ASUS router and your GS752TP switch offers increased bandwidth over a link of up to 2 Gbps.
    ASUS router LAG port 1 and 2 Dynamic Link aggregation (802.3ad)
    NETGEAR GS752TP switch the LAG Type should be change from Static to LACP.
ProSupport for Business
