iSCUBA4sharks's avatar
Oct 30, 2017
Cannot install Smart Control Center due to Bitlocker
SCC version: release v1.1.3.4 firmware version: (2.0.1.26 - ultimately, I'm trying to upgrade to 2.0.1.40) OS: Windows 10   There seems to be an issue with the installer not playing nice with Bit...
  • DaneA's avatar
    DaneA
    Nov 05, 2017
    @iSCUBA4sharks,
    The  JGS516PE switch has a default IP address of 192.168.0.239.  This is indicated on the JGS516PE user manual here on page 8.  Hope that you were able to read that part since I gave you the pages that you have to read in on how to Access and Configure the switch using a Web Browser or using the ProSAFE Plus Utility.
    It would be best if you will assign a static IP address to the JGS516PE switch that is within the IP range of your existing network for ease of management.  Here are the steps below:
    1. Disconnect the JGS516PE switch from your existing network.
    2. Connect a PC directly to a LAN port of the JGS516PE switch.  Just the PC and the JGS516PE switch connected to each other.
    3. Set a static IP address of 192.168.0.210 to your PC.
    4. Open a browser like Google Chrome or Firefox then at the address bar of it, type 192.168.0.239 then press Enter. Login to the user interface of switch. Enter "admin" as the username and "password" as the password.
    Note: The default IP address of JGS516PE is 192.168.0.239.
    5. The Switch Information page displays. In the DHCP Mode menu, select Disable.
    6. Enter the IP Address that you want to assign to the JGS516PE switch that is within the IP range of your existing network as well as the Subnet Mask, and Gateway Address of your existing LAN network on the fields provided.
    7. Click Apply.
    Note: As soon as you click Apply, you will lose access to the JGS516PE switch.  Set the PC back to 'Obtain an IP Address Automatically' or set a static IP address on the PC that is within the IP range of your existing network.
    As reference to the steps above, kindly read pages 14-15 of the JGS516PE user manual here on how to assign a static IP address to the JGS516PE switch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
