njguitarman
Mar 03, 2019Aspirant
Connecting 2 JGS524Ev2 Smart Switches over single cable - with mirror port to work across both units
Hello. I have 2 JGS524Ev2 switches on separate floors, with 1 cable.
I also have this unit: https://www.dualcomm.com/collections/network-tap/products/gigabit-copper-network-tap, which sits bet...
- Mar 03, 2019
Please read this thread. This will not work since the switch does not support RSPAN.
RSPAN allows you to monitor traffic from source ports distributed over multiple switches, which means that you can centralize your network capture devices.
schumaku
Mar 03, 2019Guru - Experienced User
njguitarman wrote:
I'm trying to get the data from the dualcomm from floor 1 to floor 0.
As I said - no need to configure any mirror ports. Create a VLAN and configure accordingly so you have a virtual "cable" from the Tap to the Sniffer.
But we're looping here... also if you had high end managed switches with RSPAN this would not be required for your purpose - which is in brief replace a simple network cable from the Tap to the Sniffer.
njguitarman
Thank you. I appreicate your reply.
