krul876
Aug 22, 2023Aspirant
Re-enabling HTTP from CLI
I was trying to add a management IP to my switch via the Access Control method and I saved the configuration to SSH (which was silly of me). I am now able to connect using Putty to the command line a...
schumaku
Aug 23, 2023Guru - Experienced User
In absence of physical serial console port, and without IP access ...? Figure 8-/
GS728TP is very vague and unclear, the supported commands - for select models - are here Lite CLI Reference Manual Smart Switches.
