ZSasha's avatar
ZSasha
GS108Ev3 Port Trunking
Hello,   Could someone explain please, is trunking available for GS108Ev3 switch? I read specs and datasheet and for 8 ports model it says "Link Aggregation/Port Trunkin" - NO and only supported o...
  • DaneA's avatar
    Mar 29, 2017
    Hi ZSasha,
    Welcome to the community! :)
    If you connect 2 GS108Ev3 switches together, you can set the ports of each switch as a tagged port (trunk port).  Kindly read pages 49-50 of the GS108Ev3 user manual here.
    The GS108Ev3 switch does not support LAG (Link Aggregation) while the GS108Tv2 supports LAG.
    ProSAFE Gigabit Web Managed Plus Switches (such as GS108Ev3) gives user the flexibility to configure certain static layer 2 settings in order to improve network efficiency and performance.  The configurable features are Port Mirroring, VLAN, QoS, Rate Limit, and Broadcast Storm Filtering.
    On the other hand, ProSAFE Smart Switches (such as GS108Tv2)  has many of the benefits of a managed switch without the complexity or cost of a fully managed switch. With a smart switch, you can monitor ports, configure trunks, and set prioritization, all with an intuitive Web interface.  A smart switch has more capability than an plus switch, but not all that of a fully managed switch.
    Kindly check the GS108Tv2 data sheet here.
    I would prefer the GS108Tv2 over the GS108Ev3.
    DaneA
    NETGEAR Community Team
ProSupport for Business
