jmstanley
Nov 27, 2025Follower
gs108v2 gs308ep DoS
I have both of those switches... The port turns off and has to be enabled to back on. The gs108v2 is connected to the gs308ep (poe is turned of on port 1 which connects to the gs108v2 port 1). Th...
jmstanley
Nov 28, 2025Follower
Correct it's a smart switch not a fully managed switch... The model info I gave is correct also.
Thanks for the reply.
Nov 28, 2025Guru - Experienced User
jmstanley wrote:The model info I gave is correct
Are you sure you didn't mean the GS108eV2 or the GS108Tv2?
The GS108T has a control to disable DOS attacks, the GS108e doesn't (at least nothing in the manual)
