das2017's avatar
das2017
GS752TXS Vlan setup
Hello,   I have four GS752TXS switches stacked using the SFP ports 51 and 52 on each switch.  Everything works fine.  Now, I'm trying to set up at least two VLANs and are wondering what's the best ...
  • JohnC_V's avatar
    JohnC_V
    Jul 11, 2017
    das2017,
    The setup that you have right now is correct. You already Tagged the port going to your router and the test port 38 is set to U - VLAN 10, PVID 10. This should work on this setup unless the VLANs that you created on the router are still not set to Tag.
ProSupport for Business
