das2017
Jul 06, 2017Aspirant
GS752TXS Vlan setup
Hello, I have four GS752TXS switches stacked using the SFP ports 51 and 52 on each switch. Everything works fine. Now, I'm trying to set up at least two VLANs and are wondering what's the best ...
Retired_Member
Jul 10, 2017Hi das2017,
For further analysis, Could you please provide the config file of the Switch:
How do I send config files from my Smart Switch to NETGEAR community moderators?
das2017
Jul 11, 2017Aspirant
Hi Retired_Member,
I've sent the config file to the email listed at the bottom of the page in the link you posted.
Thank you,
