das2017
Jul 06, 2017Aspirant
GS752TXS Vlan setup
Hello, I have four GS752TXS switches stacked using the SFP ports 51 and 52 on each switch. Everything works fine. Now, I'm trying to set up at least two VLANs and are wondering what's the best ...
Retired_Member
Jul 12, 2017
Yes, please check on your laptop, make sure the PC can get correct Gateway and DNS for DHCP Server. Otherwise, it will cause host cannot access to Internet.
das2017
Jul 13, 2017Aspirant
Retired_Member,
The laptop is getting the correct DHCP address, gateway, and DNS server information, but is still unable to access the Internet. At this point, I think the issue lies with router, so I'll continue troubleshooting that.
Thank you both, Retired_Member and JohnC_V, for taking the time to assist me with switch configuration.
