BobGear
Nov 17, 2016Star
How to enable Jumbo Frames on GS116Ev2?
Hello, I have a new GS116Ev2. It came with the latest firmware installed (v2.0.1.26). I am trying to enable Jumbo Frames. I can not find the setting either in the Web interface or in the ProSafe ...
- Retired_MemberNov 20, 2016
Hi BobGear,
Welcome to Netgear Community!
For Jumbo Frame Size, we did doc in product data sheet (Jumbo Frame Support: Up to 9K packet size), it's enable by default and can't be modified. Also can't view it from Web GUI or Prosafe Utility tool. Btw, GS116Ev2 is a Web-Managed plus switch, didn't support to manage via telnet or SSH.
Let's know if you have further query, thanks.
Retired_Member
Nov 20, 2016Hi BobGear,
BobGear
Nov 21, 2016Star
Thanks, Bruce_G.
Good answers.
I still ponder if "Up to 9K" means that the maximum is 9215 or 9216 bytes? Noted that ElaineP says 9216 bytes.
Although it doesn't matter as I will run my ethernet adapters at 9000 bytes MTU.
Thanks again for answering all of my questions.
Bob
