fcorbelli's avatar
fcorbelli
How to raise fan speed on XS708T
Is it possible to raise the fan speed at say 100% ?   Currently is 21% giving MAC t=42° and PHY t=51°. Thanks to all replies.
  • Squuiid's avatar
    Squuiid
    Nov 22, 2017
    UPDATE: The Noctua NF-A4x20 PWM is an absolutely perfect fit for this, comes with all you need, and makes this switch 100% silent while keeping temperatures in check. Excellent recommendation, thank you.
ProSupport for Business
