Arnaud_D
Jan 09, 2018Aspirant
HTTP config export very long on GS724TPV2
Hello, I wanted to report an issue on our GS724TPv2 We recently bought some GS724TPV2 and for all of them its very ong to export the configuration through HTTP, the donwload last 20-30 seconds (...
- Jan 09, 2018
Almost convinced I've experienced this delay many times on some similar Smart Managed and/or Smart Managed Pro series switches - at least for the initial download. What happens in the background of the WEb UI is that - different from the tftp access - a copy of the running config is taken from the active system.
Do you experience the same when immediately re-trying the export on that specific switch model?
If you are concerned it's an issue or annoyance, create a support ticket with Netgear.
schumaku
Jan 09, 2018Guru - Experienced User
Wow - how many times you do this so this short delay is an issue?
Arnaud_D
It's not an Issue, it's annoying.
I export the config each time i do a modification on the switch, lately as we implant new switches its 1/day. With 5 (more to come) GS724TPv2, saving all the configurations from all our switches become more boring than it already was.
20 seconds is 20x longer than instant (obviously) so maybe something doesnt work correctly.
- schumakuJan 09, 2018Guru - Experienced User
