Picmention
Apr 29, 2017Star
SFP+ RJ45
Hello, I don't know if this is the right forum, but I wanted to buy a Synology DS2015xs NAS with two SFP+ Ports. I found the Netgear ProSAFE AGM734 1x 1000Base-T Modul. I did't worked until now wi...
- Apr 30, 2017
Hi Picmention,
As far as I know, the AGM734 is compatible with the SFP+ interfaces of XSM7224S as well as with the SFP interfaces of GSM7328FS. About the compatibility with the Synology DS2015xs NAS, it may or may not work.
Kindly check this link I found online and it might help. Also, its best that you ask assistance from Synology about your concern.
DaneA
NETGEAR Community Team
DaneA
May 04, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
Picmention
May 04, 2017Star
Hello,
in the end I decided to buy a Synology DS1817+ which has a 8x PCIe Port with 4x Lanes. This one is has the Intel x540-T2 on its compatibility List and we tested it now also with the Intel x540-T1. It works great with our 10 GbE Switches from Netgear over RJ45 cable. Thank you for your Support!
