marktpalmer
Oct 25, 2017Aspirant
SNMP push Text Config
Is it possible to download a Text Configuration file or a firmware Image to the GS108Tv2 switch using SNMP commands? If so, what are the correct OIDs to use? The target switch I am looking at does ...
- Nov 07, 2017
Hi @marktpalmer,
I have replied to your post here. I have edited and updated the download link with the MIB for the GS108Tv2. You can also download it here.
You may use the NMS300 to download a text configuration file or firmware image. You can download the latest version of NMS300 here.
DaneA
NETGEAR Community Team
DaneA
Nov 13, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
marktpalmer
Nov 13, 2017Aspirant
I figured out what I needed for snmp push/pulls (download/upload) from the switch. Thanks for the assistance. If anyone else is looking, please PM me for details.
- DaneANov 14, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know that you were able to figure it out. :)
It would be nice if you could kindly share here in the community the procedure you did for SNMP push/pulls (download/upload) from the switch.
Cheers,
DaneA
