Generalspace
Jul 01, 2017Aspirant
switch gs116ev2 kicked off internet arris router
Hi All, I have a GS116Ev2 switch that has run great for a year or so. My cable service updated their modem/router (arris) Firmware ver. 9.1.103s5p Now my switch looses its internet connection. The ...
- Jul 19, 2017
OK , problem taken care of it was shentel arris modem/router .The tech. call it an MTA I guess because it had phone in it. Anyway they installed a reg. modem/router and I stayed on the internet. So I bought my own modem and I am using my router. Everything is fine.
, I was sure it was them.
Thanks for the help.
Generalspace
Jul 05, 2017Aspirant
Hi,
Under monitoring-port statistic no errors. I did do the factory default same problem. Here what i did and so far I am up. I put my 4 port hub in between the router and the switch so far I am still on line, its been an hour.
I do get this message when i use the utility Error-there is a commumication problem access netgear registion server. registration process is cancelled. Please check your internet connection and regist the product next time
Generalspace
Jul 19, 2017Aspirant
