winc
Apr 20, 2023Guide
Switch to do VLANs and VLAN trunking
What is the smallest Netgear switch that will handle VLANs as well as VLAN trunkling. TIA.
- Apr 27, 2023
Hi winc ,
You can opt for the below switch models for your mentioned specifications
16-Port Gigabit Ethernet PoE+ Smart Switch w/ optional Cloud/Remote Management and 2 SFP ports (180W)
16-Port Gigabit Ethernet PoE+ Smart Switch w/ optional Cloud/Remote Management and 2 SFP Ports (300W)
Have a lovely day,
Anisha A
Netgear TeamIf your issue is resolved please close the thread by clicking "Accept as solution".
winc
Apr 24, 2023Guide
Thanks Schumaku.
5 ports would be adequate.
10/100/1000 port speed will work as long as it auto-negotiates.
LACP LAG preferred.
Configurable/Smart managed preferred.
PoE preferred.
Do you know if Netgear has a chart/matrix that compares/shows the capabilities of their switches?
AnishaA
Apr 27, 2023NETGEAR Employee Retired
Hi winc ,
Have a lovely day,
Anisha A
Netgear Team
- wincApr 27, 2023Guide
Thank you Anisha.
