burgdoas
Jul 14, 2026Aspirant
Switches indicate receiving signal, not detecting devices
I have had a GS316EP for 4 years. It was used to power 2 PoE cameras and for my home office. About a month ago, it stopped working. When I plug the Cat 5e from the router into each port, they light u...
Jul 15, 2026Guru - Experienced User
When you swapped the switches, did you also use the new power adapter with the new one? Or did you just plug in the old one?
Does disconnecting the two PoE clients make any difference in the symptoms?
