HomeServerGuy
Dec 02, 2016Aspirant
Time Configuration problems on a GS724Tv4
I am having problems getting the SNTP Time Configuration client to work. Its doesnt even look like its trying to get a time from any server I enter. Has anybody got any advice on how to make it work?...
- May 09, 2019
Here are the steps in troubleshooting Time Configuration on a NETGEAR Smart Switch:
1. Make the firmware is on the latest version.
2. On the SNTP Server Configuration Address, try to use an NTP pool specific to your country. For example: if you are in Czech Republic, use cz.pool.ntp.org or the equivalent IP Address of the NTP pool.
3. Check if you have a DNS configured on the switch.
4. Try to set the IP Address of the default gateway on the SNTP Server Configuration Address.
5. Factory reset the switch and start from scratch.
6. If the same problem occurs after trying the steps above, kindly open a chat or online support ticket with NETGEAR Support at anytime.
DaneA
NETGEAR Community Team
r8899
Aug 28, 2017Aspirant
How could be explained difference between GS724Tv3 GS724Tv4 (see pictures in my previous post)?
The same configuration of SNTP is working on GS724Tv3, but not working on GS724Tv4.
Of course, I have tried several DNS NTP servers (DNS server is set correctly on my GS724)
r8899
Aug 29, 2017Aspirant
No progress after 1 day:
DNS client in GS724 is working well.
- DaneAAug 29, 2017NETGEAR Employee Retired
Thanks for the feedback. How is everything connected? Kindly post a diagram of your detailed network setup.
Also, have you tried to factory reset the GS724Tv4 then reconfigure it from scratch and check if same problem will occur?
DaneA
