Varatex's avatar
Varatex
URGENT/11 and Netgear Switches
Hey everybody,   Does anyone know if Netgear uses VxWorks on their switches?  A quick Google search makes it sound like they've at least used it in the past for some of their equipment.  I was hopi...
  • DaneA's avatar
    DaneA
    Aug 13, 2019
    @Varatex,
    NETGEAR constantly monitors for both known and unknown threats. Being pro-active rather than re-active to emerging security issues is fundamental for product support at NETGEAR.
    Kindly check the link below for upcoming updates:
    NETGEAR Product Security Advisory
    DaneA
    NETGEAR Community Team
ProSupport for Business
