hacesoft
Mar 03, 2020Tutor
Reflex filters
hi,
I want to ask: umi Gigabit Ethernet Smart Switch GS724Tv4 ProSafe, 24 ports, 6.3.1.34 reflex filters? Thank you for answer.
- Mar 05, 2020
DaneA
Reflexive ACL's are available on fvery few platforms only, e.g. Cisco IOS, but not on Cisco NX-OS (on switches worth then thousands of USD!!! Was told it's a hardware limitation - so you see the importance). Huawei might have something similar on their managed switches.Definitivley not a feature available on the level of Smart Managed Pro (Web managed) switches.
DaneA
Mar 05, 2020NETGEAR Employee Retired
What do you mean by "reflex filters" that you are referring to? Unable to find "reflex filters" in the GS724Tv4 user manual here.
DaneA
NETGEAR Community Team
DaneA
Thank you for your feedback.
Is there a specific RFC to the "reflex filters" you are referring to? If yes, kindly provide the RFC.
DaneA
- schumakuMar 05, 2020Guru - Experienced User
DaneA
