Moussa854's avatar
Moussa854
URL filtering
Can I increase the number of URL filtering to more than 10?
  • Moussa854 wrote:
     The two WAN Interface DNS entries are grayed as this is a dynamic interface type.
    That's why it can't work - RaghuHR the WAC510 UI needs to be enhanced so the admin can define his own DNS server IP addresses please!
  • schumaku's avatar
    schumaku
    Probably not - considering it's limited reach (does not work on https, does not work for many Apps) the the feature can be removed from these wireless APs every day. Matter of fact, the feature is not even listed on the WAC505/WAC510 tech specs.
    • schumaku's avatar
      schumaku
      RaghuHR wrote:
      Moussa854 Currently you can add up to 10 entries maximum.
      When can you remove the (honestly: useless) feature? It's just adding overhead to the code, slowing down proessing. Zero added value for security.
      • Moussa854's avatar
        Moussa854
        So, I am trying to block the adult site and others and I was not able to get it to work with OpenDNS, any suggestion?
        Best,
ProSupport for Business
