FED1920's avatar
FED1920
Tutor
Jun 04, 2023
[XR1000] eFootball Geo-Filter
Hello,
When I'm playing on eFootball game by filtering out a specific server (the belgian one), I'm still forwareded to that server which is not set on my autorized zone on the GeoFilter.
The game is then voided after the beggining of the match, whereas it should be voided before the matchmaking
Is there any setup that fix this issue ?
Many thanks
  • Try this:
    Quit the application/game/client completely
    Remove device from the Geo-Filter
    Give PC PlayStation Device Type in the Device Manager (if on PC)
    Resync from the Geo-Filter Map menu
    Re-add the device to the Geo-Filter with the manual option
    Set up the Geo-Filter how you like
    Wait 2 minutes
    Boot up application/game/client
    Then you should see icons on the map again. Then trying allowing the server that you're seeing outside the range.
  • Most likely you have strict mode disabled (you need it enabled) or you have Ping Assist enabled (needs to be set to 0 to force specific servers).
    • FED1920's avatar
      FED1920
      Tutor
      Strict Mode is enabled and Ping assist disabled, and still have this issue
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Can you provide a screenshot of what you're seeing on the map when you're getting that server please?
