hacesoft
Mar 03, 2020Tutor
Reflex filters
hi,
I want to ask: umi Gigabit Ethernet Smart Switch GS724Tv4 ProSafe, 24 ports, 6.3.1.34 reflex filters? Thank you for answer.
- Mar 05, 2020
DaneA
Reflexive ACL's are available on fvery few platforms only, e.g. Cisco IOS, but not on Cisco NX-OS (on switches worth then thousands of USD!!! Was told it's a hardware limitation - so you see the importance). Huawei might have something similar on their managed switches.Definitivley not a feature available on the level of Smart Managed Pro (Web managed) switches.
DaneA
Mar 05, 2020NETGEAR Employee Retired
Thank you for your feedback.
Is there a specific RFC to the "reflex filters" you are referring to? If yes, kindly provide the RFC.
DaneA
NETGEAR Community Team
schumaku
Mar 05, 2020Guru - Experienced User
DaneA
