JD33333
Aug 06, 2020Initiate
Registration Key
Hello, I want to ocnfigure this switch offline, however i don't get a full menu. I can login with the default password but that is only limited functions. I regsitered it and have a registra...
- Aug 07, 2020
In maintenance i didn't see the option, but i connected to internet and did a firmware update after which the key was asked.
This thread can be closed
schumaku
Aug 06, 2020Guru - Experienced User
On the taged GS110TPP operating current firmware - when I have it right - there is the input field and two buttons [Submit] (to push the offline registration key) and [Login] (for the login password).
On the screenshot there is a GC510PP - never done offline registraion on the Insight [GC] switches. One would assume it would be similar. Ensure there is the current firmware in place - as of writing GC110 / GC110P / GC510P / GC510PP Firmware Version 1.0.5.29 . In case there is still only one button and the key can't be uploaded (double check there are no leading or trailing character like spaces or <cr><lf>) we need Netgear assistance or support.
