JD33333
Aug 06, 2020Initiate
Registration Key
Hello, I want to ocnfigure this switch offline, however i don't get a full menu. I can login with the default password but that is only limited functions. I regsitered it and have a registra...
- Aug 07, 2020
In maintenance i didn't see the option, but i connected to internet and did a firmware update after which the key was asked.
This thread can be closed
Iphie_C
Aug 06, 2020NETGEAR Expert
Hi JD33333
Thanks for choosing Netgear switch.
If you are managing the switch offline in switch local web-broswer based GUI, you can login to the switch GUI and go to "Maintenance" menu to enter the registration key.
After the switch is registered and the registration key is entered, you will be able to access the full switch GUI.
JD33333
Aug 07, 2020Initiate
