loboexe
Feb 03, 2017Aspirant
Routing Between Multiple Subnet
I have two "home" routers. One from from my ISP to provide internet access on 192.168.1.x, and one for WiFi access on 192.168.0.x and then out to the first router as the gateway. I do this for tw...
- Feb 13, 2017
Hi loboexe,
I understand that the IP range of the second router is 192.168.0.x, I'd like to know if it a 1.x IP from the first router. It looks very complicated, it appears that you have configured the second router as another router. I'm looking at VLAN routing, but it seems to be inapplicable on this kind of setup.
Thanks,
JohnRo
Feb 06, 2017NETGEAR Employee Retired
Hello loboexe,
Welcome to the community!
Can you post a diagram of your projected network setup? A rough sketch will do. This will help us to give you the correct network advice.
Thanks,
- loboexeFeb 10, 2017Aspirant
This is a temp fix untill I get the software router firewall installed. I want to be able to get to the Wifi Printer from the LAN. The LAN is 192.168.0.x and the WiFi is 192.168.1.x
- JohnRoFeb 13, 2017NETGEAR Employee Retired
Hi loboexe,
Thanks,
- JohnRoFeb 16, 2017NETGEAR Employee Retired
Hi loboexe,
I'd like to get some update on this.
Thanks,
