loboexe
Feb 03, 2017Aspirant
Routing Between Multiple Subnet
I have two "home" routers. One from from my ISP to provide internet access on 192.168.1.x, and one for WiFi access on 192.168.0.x and then out to the first router as the gateway. I do this for tw...
- Feb 13, 2017
Hi loboexe,
I understand that the IP range of the second router is 192.168.0.x, I'd like to know if it a 1.x IP from the first router. It looks very complicated, it appears that you have configured the second router as another router. I'm looking at VLAN routing, but it seems to be inapplicable on this kind of setup.
Thanks,
JohnRo
Feb 09, 2017NETGEAR Employee Retired
Hi loboexe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
