remosito
Sep 19, 2019Aspirant
S3300-28X: behaviour after managment unit conflict.
If a managment unit conflict is detected (for whatever reason). And a new election is held and a new management unit is assigned. According to log files other stack member will reset and rejoin. ...
remosito
Oct 02, 2019Aspirant
Hi again,
tried contacting support, but after entering Serial Number and Date of sale it tells me my 90 day support ended already. And I have to buy some support contract.
Now I might consider doing that if I actually had a real support case! I don't.
All I wanna know is
if I see this in my logs:
Keller-2 UNITMGR[unitMgrTask]: unitmgr.c(6588) 699 %% Reset initiated on unit 2, reason: Stack manager conflict resolution Keller-2 UNITMGR[unitMgrTask]: unitmgr.c(5347) 698 %% Management unit conflict was detected and this unit has lost the manager election. All the units in this stack will reset and join the winner stack manager 8:bd:43:6e:75:d0
does that Reset mean actual reboot of units.
I really shouldn't have to buy a support contract for what is in my opinion essentially information that should be publicly available in either a manual or a FAQ.
Could you please reask the support guys on your end to confirm reset here means "it is a reboot" or "it is not a reboot".
DaneA
Oct 09, 2019NETGEAR Employee Retired
I got a feedback from the higher tier of NETGEAR Support that the word "reset" in the logs you have posted means reboot. From the logs, it means that it is a reboot of the stack member which is unit 2.
DaneA
NETGEAR Community Team
- remositoNov 07, 2019Aspirant
Hi DaneA,
totally forgot to reply to you and thank you for your effort to get to the bottom of this! Very much appreciated!
cheers
remo
