schaferk
Jun 26, 2019Follower
S3300-28X (GS728TX) volatility
Need a certificate of volatility for the S3300-28X switch
- Jun 26, 2019
Hi schaferk,
Welcome to our community! :)
Here is the letter of volatility for GS728TX. The link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
JohnC_V
Jun 26, 2019NETGEAR Employee Retired
Hi schaferk,
JohnCarloV
