JaritVB
Feb 08, 2022Aspirant
S3300-28X-PoE Can't add routable VLan
I have an S3300-28X-PoE. It's been working great, i have it in stacked mode with another S3300-28X-PoE and have been using it as a core switch in a small Business. (Call Center). I've been using it w...
JohnC_V
Feb 11, 2022NETGEAR Employee Retired
Hi JaritVB,
Welcome to our community! :)
It seems that you were having issues with creating VLAN with your switch. May I know what do you want to achieve on the new VLAN? Are you planning to create a routing on the VLAN that you created or you just wanted to assign tagged and untagged ports? You can assign ports by going to Switching > VLAN > Advanced > VLAN Membership.
Please also make sure that the switch is running on the latest firmware. If not, please do upgrade the firmware to its latest version.
John
NETGEAR Community Team
JaritVB
Feb 11, 2022Aspirant
Hi John,
I had created 15 previous routing Vlans with no issue.. but hit the error when trying to add the 16th routable Vlan. It appears that 15 routable VLans is the limit for this switch. Is this the case?
