JaritVB
Feb 08, 2022Aspirant
S3300-28X-PoE Can't add routable VLan
I have an S3300-28X-PoE. It's been working great, i have it in stacked mode with another S3300-28X-PoE and have been using it as a core switch in a small Business. (Call Center). I've been using it w...
JaritVB
Feb 11, 2022Aspirant
Hi John,
I had created 15 previous routing Vlans with no issue.. but hit the error when trying to add the 16th routable Vlan. It appears that 15 routable VLans is the limit for this switch. Is this the case?
schumaku
Feb 11, 2022Guru - Experienced User
Data Sheet | S3300-28X, S3300-28X-PoE+, S3300-52X and S3300-52X-PoE+ p.8
Performance Specification
Number of routed VLANs 15
