boed's avatar
boed
Tutor
May 01, 2022
S3300-28X-PoE+ ProSAFE no POE power - power page won't show any details
I tried the latest firmware s3300v6.6.4.26 as well as the previous.
Unit No.Model NameBoot VersionSoftware Version
1S3300-28X-PoE+B1.0.0.126.6.4.25
I can go to any page on the management gui EXCEPT the power page.  If I select any of the POE options it shows a blank right pane and I can no longer go to any previous or new management web pages.
I have tried a factory reset from the reset button as well as the gui - they do reset it to factory defaults but no luck on POE.
I have tried two different power cords at different outlets - used one which was powering another Netgear POE switch.
I have tried multiple POE devices with different ethernet cables - no luck - same devices and cables work on other netgear poe switch.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    boed,
    Welcome to the community! 🙂
    Based from your initial post, your S3300-28X-PoE+ needs to be replaced.  I suggest you to open a support ticket with NETGEAR Support at anytime here.   Kindly state the status of your S3300-28X-PoE+ as well as the troubleshooting steps you did to isolate the problem.  Be sure to upload a soft copy of the Proof of Purchase of your S3300-28X-PoE+ for warranty verification.  If the hardware warranty is still valid, an online replacement will be processed.
    DaneA
    NETGEAR Community Team
  • Had the exact same issue here in the UK.
    Just had the switch replaced (limited lifetime warranty thankfully) by Netgear with a GS728TXPv3.
    All good but the newer switches no longer have the copper 10G ports on ports 25 and 26 - so pack those 10G copper SFP's ;-) should you need 10G copper support.
ProSupport for Business
