gnulpt
Jul 29, 2021Follower
S3300 EOL
Hi, is the S3300 series of switches (aka GS728TX, GS752TX) soon EOL? If yes, what replacement do you recommend. Thanks
schumaku
Jul 29, 2021Guru - Experienced User
Netgear does not pre-publish any EoL intentions.
The designated successors in the stackable range is certainly in the M4300 Series family - much bigger switch model selection, much more options beyond of just GbE ports, more PoE options. Granted, somewhat more expensive if we compare the M4300-28G and -52G.
DaneA
Jul 29, 2021NETGEAR Employee Retired
Welcome to the community! :)
As far as I have checked, both GS728TX-100PRS and GS752TX-100PRS are EoL.
Be informed that the GS728TX-100PRS and GS752TX-100PRS are the product codes of the GS728TX and GS752TX switches in China. As reference about the S3300 switches product codes, kindly check page 13 of the S3300 Smart Switch Series Data Sheet here.
DaneA
NETGEAR Community Team
