Eberhard_Mu
Apr 10, 2021Follower
S3300 WOL
I need help to get WOL packets routed. I have 3 switches connected by LWL: Server-S3300 #1-S3300 #2-S3300 #3-Workstations I can not send magic packets from my server to all workstations, on ever...
DaneA
Jun 09, 2021NETGEAR Employee Retired
Welcome to the community! :)
What is LWL? Are you referring to LAG (or LACP)?
Are the WOL Settings properly configured on the workstations?
What is the current firmware of your S3300 switches?
As a test, using just one S3300 switch, connect 1 workstation to it then check if WOL will work.
DaneA
NETGEAR Community Team
