spook217
Sep 29, 2023Aspirant
S350 GS348T - VLAN trunk - Switch to Switch not working
Hi All I have connected another switch on to the SFP (Port 47) on this switch and setup tagged VLAN ID on both switch trunk ports (leaving VLAN1 untagged on trunk ports). However, client pcs con...
schumaku
Oct 01, 2023Guru - Experienced User
All tagged VLANS configured and enabled on both sides of the trunk connection accordingly?
For the access ports to different VLANs - for connecting devices where you expect participation in a VLAN different from the default 1 - are properly configured as untagged for the VLAN, and the PVID is set so the untagged traffic is assigned into the VLAN you expect - and no other VLAN associations?
Is there a DHCP server or service on the other VLAN(s) where you expect clients getting DHCP assignments?
spook217
Oct 01, 2023Aspirant
Thanks for helping. I can confirm vlans are tagged on trunk ports on eack switch and PVIDs are set on access ports. The upstream switch is connected to pfsense firewall/router which has DHCP services for vlans.
