farman
Jul 14, 2022Follower
GS348T factory reset
I forgot the password to the GS348T. If I reset to factory default, I understand the default IP changes to 192.168.0.239. How do I access it with my current network IP. My firewall is DHCP. The way I understand the manual, it will automatically change to my current network IP setup. Is that correct and assign itself an IP address which I can then discover.
Thank you
Welcome to the Community!
You are right, by default the DHCP Client of the switch is enabled so once connected to your firewall it will request for an IP. You can then use the Switch discovery tool to acquire it's IP and then manage the switch.
HTH
1 Reply
