Netme
May 24, 2020Aspirant
S350 Smart Managed - bandwidth restriction
Hi, a simple question: is it possible to restrict the bandwith of one specific port with "S350 smart managed" switch? If yes, is it "straight forward" ;-) ? Thank you (asking before buying one...
- May 24, 2020
S350 Series 24-Port (PoE+) and 48-Port Gigabit Ethernet Smart Managed Pro Switches with 2 or 4 SFP Ports User Manual p187 ff. "9. Interface Shaping Rate", "10. Interface Ingress Rate Limit"
S350 Series 8-Port Gigabit Ethernet Smart Managed Pro Switch User Manual, Models GS308T and GS310TP p.177 ff. "9. Interface Shaping Rate", "10. Interface Ingress Rate Limit"
schumaku
May 24, 2020Guru - Experienced User
- NetmeMay 24, 2020Aspirant
Thank you!
