koeber
Sep 14, 2021Guide
S350 Smart Switches (GS348T) with NETGEAR Compatible 1000BASE-BX BiDi SFP?
Dear Community, can anyone confirm please if the NETGEAR Compatible 1000BASE-BX BiDi SFP can operate with S350 Smart Switches (GS348T)? I got in that Switch Log the following after inserting t...
- Sep 27, 2021
Hi,
I got in the meantime from FS.com support (Customer Support: +49 (0) 8165 8090 517) an generic compatible BiDi Modul #75335
This has another coding and works with the GS348T Switch.
Here the technical support output of my GS348T Switch with inserted SFP-GE-BX BiDi Modul #75335:*************** show fiber-ports optics-info all *************** Link Link Nominal Length Length Bit Possible 50um 62.5um Rate Speed Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance Supported Detected -------- ---------------- ------ ------ ---------------- ---------------- ------- ---- ---------------- ------------ --------- g49 FS 0 0 S2001345774 SFP-GE-BX 1300 1000BX10 Yes 1G *************** show fiber-ports optics all *************** Output Input Port Physical Port/ Temp Voltage Current Power Power TX LOS Fault Lane Number [C] [Volt] [mA] [dBm] [dBm] Fault Status ------ -------------- ---- ------- ------- ------- ------- ----- --- ------------- g49 g49-Lane1 47.4 3.270 17.7 -5.314 -40.000 No Yes Local Fault
schumaku
Sep 14, 2021Guru - Experienced User
Netgear does not offer any BiDi modules, so "Netgear compatible" relates to SFP (or SFP+) modules with a Netgear vendor and some "fake" model number in the flash.
It's well possible that certain specific features and specialities might not work, because Netgear does not offer such modules, and doesn't test such modules. I remeber some models where for example copper Ethernet modules were not workable, because the switches had not been specified and tested accordingly.
- koeberSep 15, 2021Guide
Hi schumaku,
it looks like SFP-BiDi, 1000BASE-BX Single LC SFPs are working in M4300-96x switches, see here
But not in GS348T.
Is there anything that I can do to get this working too?- schumakuSep 15, 2021Guru - Experienced User
Lack of a shell access, we customers don't have much options here. Sometimes some fiber module details are visible in the diagnostics file.
Trouble is that either way Netgear does not support these module types, not even any equivalent Netgear models. Tomorrow, with the next update, what appears to works today can fail any time.
The only chance is that Netgear does pick up this issue, and does spend time and effort on it. YeZ please.
- koeberSep 27, 2021Guide
Hi,
