barryb1
Jan 14, 2017Aspirant
Ethernet Switch compatible with Windows VISTA
I just plugged in my Windows 10 ethernet cable, and my Windows VISTA ethernet cable. I can't get on-line with my VISTA cable (tried 2 different cables). All lights are green....
Help?!
Thank you for ALL your help!! It works as I needed it to.
PS: Anyone in need of a ethernet 'switch' that I can't use?
Thank you!
- DarrenMSr. NETGEAR Moderator
What is the model of the switch that you have?
DarrenM
- barryb1Aspirant
FS205
Thanks.
- JohnRoNETGEAR Employee Retired
Hello barryb1,
Welcome to the community!
The FS205 is an unmanaged switch and basically a plug-and-play unit. Here are some things you can check:
- If you are using a router, make sure you have them setup in this order: Modem>Router>Switch>PC(clients).
- If you do not have a router, check if your modem can give enough IP addresses to the devices connected to it.
- Do an ipconfig on the vista and see if the IP address is on the same range as the other devices on the network.
To better help you with this issue, I have some questions below:
- What is the model number and brand of your router?
- Has this been working before?
- Do you get internet when the Vista PC is connected directly to the modem/router?
Thanks,
