cprichard
Jul 19, 2022Aspirant
Sanitization Procedures for GS728TPP‐200NAS
Hello, I am looking for sanitzation procedures / letter of volatility for GS728TPP‐200NAS.
Marc_V
Jul 19, 2022NETGEAR Employee Retired
cprichard
Jul 20, 2022Aspirant
Hi Marc_V.
To be sure, when the LoV mentions a "software utility", is it referring to Smart Control Center?
Thanks!
- schumakuJul 21, 2022Guru - Experienced User
No. Erasing the non-user modifiable storage will destroy the switch - it will no longer boot, the horse will be dead. This storage section does not contain any config or hidden data from the switch config or operations.
- Marc_VJul 21, 2022NETGEAR Employee Retired
It typically means Factory reset the switch. Software utility inside the GUI which is the Factory default setting. But I am pretty sure you can do that in the Smart Control utility as well but I think you might be checking on a different utility it's just the GUI or the SMC.
HTH
