churchtrotter
Jul 27, 2023Follower
Selecting the correct product(s)
I'm in search of assistance in selecting the correct product(s). I've been asked to buy a 16 Plus port PoE Switch along with 2 access points that are PoE. I'm out of my depth here. I was look...
schumaku
Jul 28, 2023Guru - Experienced User
For an average network camera, you should calculate the maximal required PoE (802.3af-2003) power of 15.4W each.
Talking wireless access points, the possible performance for wireless access points does easily exceed the commonly available 1 Gigabit/s (1000 Mbps). This might require faster switches and a much better infrastructure to be considered.
