vschroeder
Jun 23, 2020Guide
Setting up VLAN with Google Wifi. Switch "dissapears" on network.
Hi Everyone! I have succesfully setup my Smart Switch to manage the VLAN tagging to a Google Nest Wifi Router. The Wifi works fine, even the wired connection seems fine. However, when I go from the...
- Jun 24, 2020
By rule of thumb you need two VLANs. First for the Internet WAN part:
- #7 with the link towards the Telekom side VLAN 7, tagged, PVID whatever (I think, no need for handling non-tagged packets there) no other VLAN membership (!!!)
- #7 with the link towards the Google WiFi VLAN 7, untagged, PVID 7 - no other VLAN membership (!!!)
When I understand you right, this does work.
Now it seems you intend to use the switch also for the LAN with a dedicated VLAN. You could use the default VLAN 1. Ensure this is VLAN not on the two ports where Internet/WAN VLAN 7 is. So configure all other ports to VLAN 1, untagged, PVID1 - and no other VLAN membership.
The static IP (on a LAN IP, like 192.168.1.x or whatever is in use there) is required because the Smart Managed Plus type switches (except some XS variants) don't allow to limit the controller to a single management VLAN. Said tht, there is some risk in this set-up with that switch class.1 2 3 4 5 6 7 8
--VLAN1--- -7-
LAN Router, Telecom
vschroeder
Jun 24, 2020Guide
Hi there schumaku,
Thank you for your patience.
I will attempt to elaborate. What I try to archive is not really super complicated. I think!
My ISP is Deutsche Telekom and they require VLAN Tagging ID 7, if you want to bypass their own router and use PPPoE.
So hereby some fancy graphics to convey what I want:
I tried via this guide: https://kb.netgear.com/30918/How-to-configure-an-802-1Q-VLAN-on-a-ProSAFE-Web-Managed-Plus-Switch-using-the-web-interface
What works:
- Internet works on all devices. Wired, and wirelessly.
- I can wirelessly access my desktop computers.
What does not work:
- In the moment i plug in the LAN cable from the Google Nest to the Netgear managed switch, the switch simply dissapears. I can't find it with the Netgear Utility, I can't ping it on the static IP i gave it and can't find it with Advanced IP Scanner. It's simply gone.
- I can't wirelessly access my server.
I made sure that the switch is not in DHCP mode and gave it a IP address on the same subnet, with an IP within the routers pool.
So I think it could be related to the VLAN tagging, but I am not sure!
Thanks for the patience.
However, something with DHCP or similar must fail. This is my what my unexperienced tummy tells me.
schumaku
Jun 24, 2020Guru - Experienced User
1 2 3 4 5 6 7 8
--VLAN1--- -7-
LAN Router, Telecom
