vschroeder
Jun 23, 2020Guide
Setting up VLAN with Google Wifi. Switch "dissapears" on network.
Hi Everyone! I have succesfully setup my Smart Switch to manage the VLAN tagging to a Google Nest Wifi Router. The Wifi works fine, even the wired connection seems fine. However, when I go from the...
- Jun 24, 2020
By rule of thumb you need two VLANs. First for the Internet WAN part:
- #7 with the link towards the Telekom side VLAN 7, tagged, PVID whatever (I think, no need for handling non-tagged packets there) no other VLAN membership (!!!)
- #7 with the link towards the Google WiFi VLAN 7, untagged, PVID 7 - no other VLAN membership (!!!)
When I understand you right, this does work.
Now it seems you intend to use the switch also for the LAN with a dedicated VLAN. You could use the default VLAN 1. Ensure this is VLAN not on the two ports where Internet/WAN VLAN 7 is. So configure all other ports to VLAN 1, untagged, PVID1 - and no other VLAN membership.
The static IP (on a LAN IP, like 192.168.1.x or whatever is in use there) is required because the Smart Managed Plus type switches (except some XS variants) don't allow to limit the controller to a single management VLAN. Said tht, there is some risk in this set-up with that switch class.1 2 3 4 5 6 7 8
--VLAN1--- -7-
LAN Router, Telecom
vschroeder
Jun 25, 2020Guide
bless your soul.
it worked out brilliantly.
everything is working now. Switch is accessable, servers are accessable!
schumaku
Jun 25, 2020Guru - Experienced User
Kleiner Nachtrag - in der Tabelle ging etwas vergessen:
1 2 3 4 5 6 7 8
--VLAN1---- -7-
U U U U U U U T
----LAN---- Router, Telekom
Immer gerne, keine Ursache.
Grüsse aus der Schweiz!
