KlausKUN's avatar
KlausKUN
SFP+ Connection between XS716T and XR700 - Which Caable?
Hi *,
which cable do I need for an SFP+ connection between XS716T and XR700.
Greets
Klaus
  • Thanks you.  7m - DAC is ordered.
    Greets Klaus
  • schumaku's avatar
    schumaku
    What is the distance between these two devices?
    On a short distance (1...3...5...7...10 meters), you can consider SFP+ DAC (10G-DAC) cables, like SFP DAC - Direct Attach cables for 10 Gigabit connections available from Netgear as well as second source (use a price search engine).
    On longer distances, you need a pair of SFP+ fiber modules with the appropriate and matching preassembled fiber patch cable, for keeping it simple look for Multimode fiber cables and modules which are fine for up to some hundred meters. On even longer distances, you look into single mode fiber cables and modules.
    • KlausKUN's avatar
      KlausKUN
      Greets Klaus
ProSupport for Business
